115 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Setting Transparency to a linked model.
Wed, May 13, 2015 at 10:47:29 AM | Setting Transparency to a linked model.
AndyRH
Hi all,
Im currently working on Revit MEP 2015 and have been asked to create a series of 3d sectional views for a brochure highlighting our ductwork and electrical systems against the building model.
How do i adjust the transparency of both the linked building and structural models to say 50% when creating these sections so the MEP systems show more clearly?
Ive clicked on the linked models - overrides graphic in view - by category - surface transparency - option but it hasnt worked. The linked models stay the same. Please see attached dwg.
Any suggestions please?
Thanks
Andy
Wed, May 13, 2015 at 10:59:48 AM | Setting Transparency to a linked model.
Simple:  VG Tab/Revit links tab/basics pick custom / model categories tab - pick custom /select all categories the set the transparency.
Thu, May 14, 2015 at 3:06:10 AM | Setting Transparency to a linked model.
AndyRH
Thank you WWHub. Worked a treat.
Linked model view setting not working
Thu, Jan 10, 2013 at 1:17:24 PM
Linked Structural model not visible
Fri, May 3, 2013 at 11:49:55 AM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:38 AM
Linked model not staying linked
Fri, Apr 25, 2008 at 3:15:07 AM
Door # in linked revit model not updating in main model
Tue, May 5, 2020 at 5:54:11 PM
Page generation time: 1.1944
