28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Revit Assembly or Group
Mon, May 11, 2015 at 1:42:19 PM | Revit Assembly or Group
bpenalba
Hello,
I am trying to create a family with multiple families in it using existing families that i have so i can reuse this combined family in multiple projects and i want to see what the best way to do this is. I have tried to create a family using a new family template but when i insert a component there is little flexibility to edit that component in the family template(for ex. I cannot just connect a water PRV and a hose bibb). So i started playing around with groups and assemblys instead. I ended up combining the families in a project and i saved them as an assemble. At least this way i wouldnt have to make extrusions and connector elements from scratch and the combined group/family is alot more editable. Although i am not able to save an assembly to use for multiple projects. Is ther any way so save an assembly for reuse? OR is there a better workaround for creating a combined family without haveing to actually just make it from scratch?
Thank you!
Group or Assembly
Wed, Oct 4, 2017 at 3:16:18 AM
assembly
Mon, Apr 22, 2013 at 5:03:46 AM
revit assembly / group ?
Sat, Nov 26, 2011 at 10:15:06 AM
Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 4:27:20 PM
help scheduling rooms with assembly codes
Thu, Jun 6, 2013 at 11:02:19 AM
Page generation time: 9.8421
