91 Users Online (90 Members):
Forums >> Revit Systems >> Technical Support >> center line symbol
hi, i'm using Revit 2015 and what i'm trying to do is place the ℄ symble as the elevation indicator for spot elevations. we use this for fabrication. i have copied it to my clipboard and if i paste it in, i only get a rectangle in front of the elevation. if i paste it in twice, then i get 2 ℄℄. my only fix right now is to just have a CL in front of the dimension. it's not the best answer, but until i can get a better option, this will get me by. i hope that someone has found a way to do it, and can help me.
thank you
Try to learn at least one new thing every day |
You are saying you paste it into your spot elevation type properties as a prefix, correct? It is the correct font type - right?
in the spot elevation type properties, i pasted the symble in the Elevation indicator value box. that way it appears in front of the elevation text. i attached the screenshot to show you.
The 'Elevation Indicator' is a text string according to your HELP: "Elevation Indicator A text string you enter with the spot elevation. Can be displayed as a prefix or suffix."
The symbol is only under the graphics.
There may be a text style that has a CL as a text character.
When you do find a charset that has a CL as this one does, it will not show the correct character in the type propertise. In this case, it showed a comma.
Center of rotation symbol is missing |
Mon, Nov 14, 2011 at 11:21:52 AM
Dimension center line of foundation |
Thu, Oct 4, 2007 at 7:40:43 AM
Wall with fire rating symbol |
Tue, Nov 6, 2007 at 10:50:19 AM
Missing Section Symbols |
Thu, Aug 25, 2016 at 4:47:32 PM
Spot elevation - symbol line greyed out |
Tue, Jan 17, 2012 at 3:44:56 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
