151 Users Online (150 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Importing topo surface from CAD in Revit
Thu, Apr 30, 2015 at 2:26:40 PM | Importing topo surface from CAD in Revit
pintar21
Tried linking the Auto Cad file of a site I am working with. To turn the 2D topo lines into a 3D surface. But everytime I try to link it, it won't open the CAD file.
Thu, Apr 30, 2015 at 2:43:34 PM | Importing topo surface from CAD in Revit
The CAD file is newer than the Revit version you are using.
Thu, Apr 30, 2015 at 2:48:28 PM | Importing topo surface from CAD in Revit
pintar21
No the Revit is the 2015 version, CAD is the 2013 verson
Thu, Apr 30, 2015 at 2:54:31 PM | Importing topo surface from CAD in Revit
Did you open the CAD file?   It could be corrupted.
This is a pretty straight forward process.
Thu, Apr 30, 2015 at 2:58:35 PM | Importing topo surface from CAD in Revit
pintar21
Yea I did check. Nothing is wrong with the file. I watch the video more times then I can count online on how to bring in and make it 3D. My problems is I cant see the file I linked. I know how to create the surface once its in and what not. I just can't see the file, even if it has already been linked.
Thu, Apr 30, 2015 at 3:43:16 PM | Importing topo surface from CAD in Revit
And now we hear the true story.   The problem is not that it won't open as you originally posted.   It is linked but you can't see it.   Do a zoom e.   The file is way out in space.
Read up on how to import/link in your help.  If the site file and your revit file are not coordinated, use a center to center import/link.
BTW - If you looked at manage links - you would have sen that the file was linked.
Thu, Apr 30, 2015 at 4:06:31 PM | Importing topo surface from CAD in Revit
pintar21
Ok so now its there but when you go to topo surface, then create from import and choose the lines that need to be created into a 3D surface. It wont create it in 3D.... what you you suggest?
Fri, May 1, 2015 at 7:28:20 AM | Importing topo surface from CAD in Revit
Did you look at the CAD?   You said you did.   Are the contour lines really elevated?   In other words, is contour line 100 at elevation 100? and 110 is at elevation 110.   The lines must be 3D polylines!  Are the contour lines on their own layer(s)?
You said you watched the videos on how to do this.   You don't chose the contour lines to create the site.   You pick create from import and pick which CAD layers contain the 3D contours and Revit will use them.
importing Topography
Mon, Jun 5, 2006 at 8:19:08 AM
Civil 3d surface to revit topo surface
Thu, Oct 13, 2011 at 7:14:35 AM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:26 PM
topo contours are offsetting in z direction
Fri, Mar 27, 2015 at 5:42:46 PM
Import topo surface from AutoCAD to Revit??
Thu, Oct 17, 2013 at 12:49:06 PM
Page generation time: 1.9434
