71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:18 PM | Symbolic Lines and Model Lines
hank
3.5 Stars: 3 Votes
When you draw symbolic Lines in the Family Editor without having specified a work plane, your are prompted to specify one. After picking a work plane though, Revit defaults to Model Lines and you end up drawing Model Lines without even knowing it. Also, the terminology of Model Lines and Symbolic Lines is not consistent. When you are in the Family Editor, everything is as it should be: Model Lines = Model Lines and Symbolic Lines = Symbolic Lines. When in the main model however, its screwy: Lines = Model Lines and Detail Lines = Symbolic Lines. It would be clearer and more intuiitive if the nomenclature were consistent. Post edited on 2006-03-22 12:52:34
Symbolic lines
Tue, Dec 26, 2006 at 2:24:23 AM
Changing from Model to Symbolic Lines
Fri, Mar 6, 2009 at 2:13:31 AM
Symbolic vs Model Lines
Tue, Feb 14, 2006 at 6:25:03 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:42 PM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:43 AM
Page generation time: 0.8259
