81 Users Online (80 Members):
Forums >> General Discussion >> Revit Project Management >> Revit Line Weights Management
Hello,
I am trying to set up my revit lineweight table for the the 1-16 lineweights. I have a plot style table that i am referencing my lineweights from, and i have enough spaces in the 1-16 lineweights table in revit to fit all of the line weights from the referenceing plot style table. Although in the revit 1-16 table it is broken up in columns of scales and one of my line weights at 1:1 is 0.1270MM. I am able to fill in the columns from 1:1 through 1:48 for this lineweight but when i get to all the smaller scales there after i am not able to place anything in because revit will not allow me to apply a linestyle smaller than .025mm. Is there any way i can override this rule in revit? If not how would you go about placeing in the lineweight of 0.1270MM and its conversions to other scales for the other columns in the revit line weight style table of 1-16?
Thank you for your time
Revit is NOT CAD! I strongly suggest that for now, you simply use the default settings until you learn how Revit works.
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
How to match .CTB line weights with Revit |
Fri, Dec 5, 2008 at 4:11:55 PM
Revit line weights |
Wed, May 15, 2013 at 10:49:44 AM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
