101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Material Takeoff
Wed, Apr 22, 2015 at 10:42:22 PM | Material Takeoff
coastalclimbing
I have created a material takeoff and there are components such as toilets doors and windows listed with a area SF value associated. I would instead like to have a fixed cost for these items rather than a cost based off SF or area values. Is there a way to accomplish this in a Material Takeoff or should I just us a schedule and filter out these items from the materials takeoff? IS the materails takeoff an appropriate place to list these items, Whats your approach?
Thanks,
Thu, Apr 23, 2015 at 7:08:01 AM | Material Takeoff
I would do per item takeoff seperate from materials - seperate schedules.
Thu, Apr 23, 2015 at 7:46:16 AM | Material Takeoff
coastalclimbing
OK cool.
So how lets say I just want floors walls and roofs in my material takeoff is there a way to select these multiple categories when creating a takeoff rather than than selectin "multiple categories" which selects all of the elements?
Thu, Apr 23, 2015 at 8:53:46 AM | Material Takeoff
In all schedules, you can add a column that you only use for filtering purposes and then you hide it.   So maybe in this case, you curse the family name and filter accordingly.
We also add a shared project parameter to all categories for schedule manipulation (in our template and included in our template schedules).   Typically if there is an X in that parameter, the item is never scheduled.  But this field could be used in multiple ways.
Fri, Apr 24, 2015 at 9:06:58 AM | Material Takeoff
coastalclimbing
Now I am incountering a diffrent problem. I am putting togather a Materials Takeoff of the Floor layers in my project. On level 1 the floors and subsequent areas display correclty and the SF values associated. However on Level 2 with the same floor type there are no area values associated with the floor. Why would this be especially considering I am using the exact same floor type?
Mon, Apr 27, 2015 at 7:32:16 AM | Material Takeoff
We don't have enough information to answer except to say it is something in your process.
Are you sure you have a floor on that level?  It could be that the floor is on a different level and just offset to where it should be.
Ceiling Material Takeoff
Thu, Feb 15, 2007 at 3:19:58 PM
Material Takeoff issue
Mon, Oct 25, 2010 at 3:48:36 PM
Material Takeoff for insulation??
Mon, Oct 28, 2013 at 9:57:11 AM
Sheathing Material Takeoff
Mon, Apr 25, 2011 at 7:01:07 AM
Wall Material Takeoff vs. Wall Quantity Takeoff for material description
Mon, Mar 15, 2010 at 1:57:01 PM
Page generation time: 0.6213
