52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Multiple Sets of drawings
2 Posts No Rating |
How do people handle multiple sets of drawings within a project? I'm creating a CD set and a Variance set. I've created 2 sets of elevations, plans, sections etc. but it is getting difficult to make sure the "variance" sections show up in the "variance" plans. Could I attach a project parameter of "variance" and then filter out those views marked variance in the regular views? Any thoughts? Thanks!
We archive our projects at each phase and so we use basically the same views in each phase (not always).
'Variance' plans - sounds like a site plan and not many views. So they would be seperate and in their own folder.
2 Posts No Rating |
Thanks WWWhub - unfortuneatly they happen at the same time, so I've just now figured I can use a filter and combine it with a view template to hide all of the variance elevations and sections on the non-variance views and vice-versa. It's a lot of set up, but once it is in the template it will only have to happen once. Alternatively, I could have used selection sets, but that seemed a little harder to manage.
7 Posts No Rating |
Hi LTI,
I'm doing the same thing. Not sure how you are applying the filter. Could you explain a little further please?
RegardsBrent
7 Posts No Rating |
Worked it out....
In the properties pallete click view templates
Make a new view template - In the View Properties area click V/G Overides Filters
Create a new filter
Filter category "Callouts"
Apply a filter rule - We used sheet number
Same but Different |
Thu, Nov 6, 2008 at 10:22:25 AM
Titleblocks |
Tue, Aug 2, 2005 at 2:28:42 PM
Revit 2016 - Multiple Drawing Sets in Sheet Index |
Fri, Jan 12, 2018 at 10:38:33 AM
Separate drawing sets |
Tue, Dec 1, 2015 at 1:44:15 PM
Multiple Sheet sets / Revision Numbers |
Wed, Jul 2, 2014 at 3:35:42 PM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
