63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> View dependent material surface patterns
Wed, Apr 22, 2015 at 10:46:45 AM | View dependent material surface patterns
clickster
clickster Avatar
Is there a way to have a given material display different surface patterns in different views?  I am creating elevation diagrams, in which I want to assign a hatch pattern to my solid materials. I assigned a hatched surface pattern to the material, but this seems to assign the surface pattern globally, and it shows up on all my other elevations (not just the diagrams). Any help would be appreciated.
Fill what is empty. Empty what is full. Scratch what itches.
Wed, Apr 22, 2015 at 11:12:01 AM | View dependent material surface patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Don't actually change the material just override the pattern in the view.
Wed, Apr 22, 2015 at 11:49:44 AM | View dependent material surface patterns
clickster
clickster Avatar
 If I use visibility override by category, then the other objects in the category would be affected (which I don't want). Over-riding by element would be very time consuming. I was hoping there would be a way to assign a surface pattern to the material and then somehow use a view setting to change the material's surface pattern, only in that given view.
Wed, Apr 22, 2015 at 11:51:35 AM | View dependent material surface patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"Over-riding by element would be very time consuming"  What are you trying to override?  Just click on it, right click and select all instances.
Wed, Apr 22, 2015 at 1:57:55 PM | View dependent material surface patterns
clickster
clickster Avatar
ok thanks
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
Missing surface patterns in 3D [ 1 2 ]
Fri, Apr 10, 2009 at 12:46:53 PM
16
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
Dependent views not the same as Parent view...
Fri, Jun 16, 2017 at 11:02:18 AM
Page generation time: 1.8124
