80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Merging Toposurfaces
Tue, Apr 21, 2015 at 7:45:50 AM | Merging Toposurfaces
paultatham15
I want to merge these three toposurfaces in my project, but when I try merging them they dissapear! I have attached an image showing the surfaces. The centre surface has been altered quite dramatically, but when it merges to the surface surrounding it, they both dissapear, leaving a hole in the remaining surface. PLEASE HELP!
Tue, Apr 21, 2015 at 8:01:44 AM | Merging Toposurfaces
As far as I know, you can't merge seperate topogrphies, you can only merge seperate surface areas in the same topography.
From your HELP
Tue, Apr 21, 2015 at 8:03:17 AM | Merging Toposurfaces
paultatham15
I thought that too, but I've done this before, and it worked... very confusing
Tue, Apr 21, 2015 at 8:05:36 AM | Merging Toposurfaces
Not really confusing.  Again from your HELP: "....The surfaces to be merged must overlap or share a common edge...."
That means they have to have the same elevation all along their common edges.
Tue, Apr 21, 2015 at 8:07:53 AM | Merging Toposurfaces
paultatham15
Okay, I understand now. Thank you so much for your help! Saved me a lot of time.
Merging toposurfaces
Wed, Aug 12, 2009 at 3:44:36 PM
Can you tell a building pad to cut multiple toposurfaces? Revit 2014
Tue, Aug 12, 2014 at 2:45:16 AM
Merging Shared Parameters
Mon, Jun 8, 2009 at 3:08:12 PM
Beam not merging
Mon, Mar 16, 2009 at 5:57:09 AM
topo depth
Wed, Nov 7, 2012 at 1:01:23 PM
Page generation time: 0.9497
