91 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> how to remove a "Work Plane" 2008 REVISION 1 STRUCTURE
I am learning this software (maybe). I added a Work Plane to the underside of a sloped "shed" roof to, I thought, be able to generate a view of the framing of this roof. Didn't work out as the grid of this work plane is not parallel to the column lines plus it seem impossible to be able to add framing on the slope of the roof. Can this work plane be removed?
Why are you using 2008? UPGRADE!
If you are just using a free version, you can still do that - just download it. 2016 is now out.
I use 2008 because it's paid for. The "Free" new version is only free so someone can try it out: it disappears after a while.
So I wonder if someone who has used Structure for a long time can give me a answer/
Thanks for your help
CAD software limitation with Revit Structure 2008 |
Mon, Dec 3, 2007 at 10:22:16 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash |
Tue, Jul 28, 2009 at 1:36:33 AM
Calculated field on sheet to state whether "numeric" or "Alphabetic" no. used |
Tue, Jul 10, 2012 at 7:07:05 AM
ABOUT SET UP WORK PLANE |
Thu, Aug 5, 2010 at 9:30:56 AM
The definition of "Front" in 3D View and rotating a complete structure |
Thu, Jun 30, 2016 at 7:53:41 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
