Forums >> Revit Systems >> Technical Support >> Invert Elevation Vs. Spot Elevation
I incorporated the Invert elevation apart of my Custom Pipe Tag i created, and when i used the spot elevation command. There is a 1/2" bust between my tag and the apot elevation. What is the difference between the "Invert Elevation" parameter available in Labels, and Spot elevation? Where is that 1/2" bust comming from. I checked the tolerances and they are both the same (round to the nearest 1/8"), and the pipe thickness of the pipe i am referencing isn't an 1/2". Does anyone out there know what causes this?
Snip attached...
Oh by the by, the spot elevation is referencing Bottom of Pipe.***
The Invert Elevation is bottom of the Inside Dia., whereas the Spot Elevation is the bottom of the Outside Dia. The difference is the thickness of the pipe wall (if you don't round).
Thats what i was thinking, but i just wanted to make sure. Greatly appreciated for the clearing of the fog. I can see clearly now. Thanks again kind sir.
invert elevation tag |
Thu, Aug 27, 2009 at 6:26:28 PM
Invert elevation tag for plumbing fixtures |
Wed, Aug 17, 2011 at 11:21:33 PM
Spot Elevation vs. Level elevation |
Wed, Feb 14, 2018 at 6:13:21 PM
Invert Elevation Tag |
Wed, Jul 23, 2008 at 11:24:54 AM
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:56 PM
Members: | 2100785 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
