149 Users Online (147 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Schedule Grid is not showing up property
Thu, Apr 16, 2015 at 5:31:13 PM | Schedule Grid is not showing up property
duydtran87
I am running bootcamp, its seems like the GUI scaling is off for the grid. Any easy fix?
Thanks
Sun, Apr 19, 2015 at 4:19:52 AM | Schedule Grid is not showing up property
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I have the same bootcamp setup and have the same problem.
The schedule will display properly in a sheet.
But if you need to edit it outside of a sheet, you will need to increase the size of each of your columns and / or adjust your text size.
Column grid not showing up
Thu, Jan 24, 2008 at 11:49:48 AM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:57 PM
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
Property Lines on Toposurface
Mon, Jul 9, 2007 at 10:22:49 AM
column grid visibility
Wed, Nov 15, 2006 at 3:43:13 PM
Page generation time: 0.6516
