129 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> Material tag not tagging!
Thu, Apr 16, 2015 at 10:36:11 AM | Material tag not tagging!
etrod1968
i have a materal tag that used on a 2nd floor plan (works great)
but when i try to use the materal tag on my foundation plan i does not show up.
i've check all setting i could think of. anybody have a idea?
Thanks.
Thu, Apr 16, 2015 at 10:51:50 AM | Material tag not tagging!
What are you trying to tag?
Is site/topography on and possibly hiding what you want to tag or maybe a floor?
Thu, Apr 16, 2015 at 11:38:06 AM | Material tag not tagging!
etrod1968
i set up a material tag for a TDS i set up a TDS materal and it works fine on my mezzanine plan so i know the tag works
but it wont work on my fondation plan.
Thu, Apr 16, 2015 at 12:12:46 PM | Material tag not tagging!
We try to help but we can only work with what you give us.   I asked what (element), not what material.  And TDS - what the heck does that stand for?   You need to ask your questions clearly and provide some images when possible because that answers a lot.
Thu, Apr 16, 2015 at 2:02:27 PM | Material tag not tagging!
etrod1968
TDS IS A "TURNED DOWN SLAB" EDGE WHICH IS A PROFILE. SINCE I CANNOT TAG A PROFILE I FOUND A WORK AROUND THAT YOU CREATE A MATERIAL CALLED (TDS0.7) FOR 8" TURN DOWN SLAB AND USE A MATERIAL TAG TO LABEL IT.
THE MATERIAL TAG WORKS ON MY MEZZANIE PLAN BUT NOT MY FOUNDATION PLAN.
NOT SURE WHY
Thu, Apr 16, 2015 at 2:17:59 PM | Material tag not tagging!
You can tag it in plan because you can see it!  You have to see the material and slab edge profiles are typically placed under the slab.  Here is a slab with a standard slab edge on the right.  You can tag it in section but not plan.  On the left is a junk slab edge who's profile makes it come above the slb.  You can tag it in section and plan.
Thu, Apr 16, 2015 at 2:32:21 PM | Material tag not tagging!
etrod1968
I understand that but the material tag will not even tag my wall or anything in that view. in the visibility/graphics box that material tag is checked.
!!!!! I fixed it but not sure how? i set up a foundation plan view template and a mezzanine plan view template when i started this job so im my foundation plan i switch the foundation plan view template to mezzanine plan view template and it worked. i have a box check somewhere in that template that i can not find.
thank you for your help.
Thu, Apr 16, 2015 at 2:38:29 PM | Material tag not tagging!
Look at the view template - annotations - Material Tag.
Fri, Apr 17, 2015 at 7:38:03 AM | Material tag not tagging!
etrod1968
That was one of the first things I check. but thats not it.
work around i just used the mezzanine template and renamed it.
Tagging Subregions in Topography
Mon, May 21, 2012 at 7:45:11 AM
material tagging a family
Mon, Apr 15, 2013 at 4:12:47 AM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:14:58 PM
Tagging a Glass with unique/sequential numbers
Tue, Aug 6, 2013 at 3:15:39 PM
Material tag and doors
Mon, May 29, 2006 at 5:04:08 PM
Page generation time: 0.8379
