54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> slab with 2 slopes
Wed, Apr 15, 2015 at 8:20:23 AM | slab with 2 slopes
amrghanem
I have a ramp that has 2 slopes as shown...any help??
Wed, Apr 15, 2015 at 8:32:43 AM | slab with 2 slopes
Use two ramps.... or two floors.
Wed, Apr 15, 2015 at 8:43:12 AM | slab with 2 slopes
amrghanem
I tried to use 2 floors but I couldnt determine the start edge of the second slab (slope arrow's tail) cause the first slab doesnt "completely" appear in the first level and it totally disappear at the second level
Wed, Apr 15, 2015 at 8:52:35 AM | slab with 2 slopes
Goto an elevation view and add a vertical reference plane (temporary) at the end of the first ramp.
Wed, Apr 15, 2015 at 9:22:17 AM | slab with 2 slopes
The problem with both slabs and ramps is that they both need to extend to the bottom intersection point ... they need to overlab in order to join correctly or you have to add some sort of element to fill in that wedge.
Multiple sloping slab on grade
Wed, Sep 28, 2005 at 11:20:27 PM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
compound slab or roof slopes
Wed, May 27, 2009 at 7:19:30 AM
Auditorium Floor Multiple Slopes
Fri, Feb 22, 2008 at 12:31:24 PM
Auditorium: multiple levels/slopes slab on grade approach.
Sat, Jan 30, 2010 at 4:20:42 PM
Page generation time: 0.2931
