74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Parts in IFC without door/window opening
Fri, Apr 10, 2015 at 5:59:01 AM | Parts in IFC without door/window opening
Profiil
When I export my project into IFC then some parts created do not have openings in them. When exported as original then everything is there.
While using the same window family with the same instance parameters and the same wall type,  some have the openings, some don't.
I always export only items which are seen and parts are exported  as building elements
As it is building made of precast elements, then it would be nice to show the parts but it seems silly when some of the doors and windows are filled with wall. Everything is OK in RVT file.
any idea or helps is welcome.
Tue, May 12, 2015 at 10:08:25 AM | Parts in IFC without door/window opening
Profiil
Still got this problem
using Revit 2014 and got the newest ifc exporter from sourceforge.
Opening numbers
Mon, Dec 19, 2005 at 3:07:30 AM
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:47 AM
Door parameter: IFC Parameters: Operation, how can I use it?
Fri, Oct 2, 2009 at 8:53:26 AM
demolish door with out infilling opening
Fri, Jun 5, 2015 at 9:30:40 AM
Wall opening (door)
Tue, Mar 31, 2015 at 10:58:13 AM
Page generation time: 0.5391
