64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> structural columns
Tue, Mar 21, 2006 at 3:30:52 PM | structural columns
gdoorn
1 Stars: 1 Votes
i am dropping some W-sections and some HSS columns into my 1 story model. i cannot attach the columns to the generic roof that we have. the roof is sloping, and other than cutting a quick section at each column location to determine height to the roof, is there a quick way to get the columns at the appropriate height?
Mon, Mar 27, 2006 at 4:02:53 PM | RE: structural columns
sjmintz
Visually, you can create a reference plane locked to the top of the roof (or offset 1" above). You can then use this reference plane to cut each and every column. That's the only solution I've found so far.
Mon, Mar 27, 2006 at 4:10:45 PM | RE: structural columns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Looks like version 9 could possible have a fix for this...
structural wall VS structural columns
Tue, Apr 26, 2016 at 3:49:40 PM
Structural columns
Mon, Jan 16, 2012 at 8:37:33 AM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:26 PM
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:12 PM
Structural graphical columns schedules
Mon, Apr 25, 2016 at 3:19:19 PM
Page generation time: 0.5538
