146 Users Online (145 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Horizontal dimensions on sloped items
Tue, Apr 7, 2015 at 10:36:14 AM | Horizontal dimensions on sloped items
AnejoDave
I have a family that is on a sloped slab that needs to be in a live view.  I need to be able to dimension the item's true horizontal dimensions from the sloped and forshortened elements.
Is there a way to do that in Revit 2014 without overriding the dimensions manually?
Use "Hide in View" and you're a nazi terrorist who takes the last beer
Tue, Apr 7, 2015 at 10:47:32 AM | Horizontal dimensions on sloped items
First you mean in a plan view - correct?
And when you say "...the item's true horizontal dimension.."  Do you really mean that?  The true horizontal is just that in the current view.
If you mean you want to show the true length (if flat), then the answer is no.  You can show that in a section view at an angle.  Obviously if you over-ride the dimension, you better add a qualifier that says something like "SLOPED LENGTH".  Or better yet, allow the true horizontal and add underneath that the sloped length with qualifier all in paranthesis.
Tue, Apr 7, 2015 at 11:20:03 AM | Horizontal dimensions on sloped items
AnejoDave
I did mean in plan view.
I figured it couldn't be done.  So my solution will be to make the sloped element a 2D component and lay that over the live elements.  It's cheesy but it'll get the job done according to the criteria we're mandated to use.
Recessed Lights in Sloped Ceiling
Thu, Dec 13, 2007 at 10:23:29 AM
How to make the top of the wall not horizontal?
Sun, Jan 23, 2011 at 7:17:42 AM
Can't select model items by clicking
Wed, Sep 30, 2009 at 12:52:51 PM
Door in sloped wall, need help building frame
Mon, Jun 23, 2014 at 2:25:12 PM
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:47 PM
13
Page generation time: 0.4292
