84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Hanger Point Loads
Tue, Apr 7, 2015 at 7:51:47 AM | Hanger Point Loads
vinnygolfer
4.5 Stars: 4 Votes
good morning all, i'm using Revit 2015 and would like to know if anyone knows if it's possible to have Revit calculate the point loads for hanger points? we do jobs occationally that require it, and so far i can't figure out how to get that information to populate.
thank you
Try to learn at least one new thing every day
Tue, Apr 7, 2015 at 8:00:02 AM | Hanger Point Loads
Vinny.... I would think you would have to include two reference planes in your hanger family to show spacing (instance) or an instance parameter 'spacing' that would be entered when you place the hanger.  You would also need a pipe weight parameter - again that you fill in.  Then obviously a schedule can do the math.
If you want the family to do it, then the parameters would have to all be type - right?
Parametric Pipe hanger
Tue, Sep 2, 2014 at 3:58:06 PM
Using a Steel Angle as a Hanger or Column
Mon, Oct 12, 2009 at 7:04:25 PM
adding existing loads to a panel schedule?
Thu, Mar 28, 2013 at 3:56:42 PM
Internal Point, Line and Area Loads...Internal???
Fri, Dec 14, 2012 at 4:59:06 AM
Point Cloud in Revit 2014 no longer working in Revit 2015
Fri, May 15, 2015 at 3:23:06 AM
Page generation time: 0.4239
