59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Sections tag
0 Posts No Rating |
Greeting to all
I have depended duplicate plans ,
And every plan 4 part,
Once I put sections tags, it appearing over each other,
Is there a way to filter it that I can control it in every view ?
Thanks for all
Do you understand how and when to use dependent views? Maybe not.
Dependent views are best used with divided up / match line plans. They all carry the same information for the area shown. This can be a problem when you have call-outs near the match-line or crossing it. In that case, you might hide some of those and use some other tricks. You really don't say how you are using these so I can't address your question furthur.
0 Posts No Rating |
I'm already divided my project to four parts, using dependent duplicate
And its all fine, only facing problem with sec tags, once I have tages one for 1/100 And the other for 1/200,
I tried to filters, but I didn't catch it, so I'm going through hide elements in every view,
Thanks for you,
What tags? I sure don't know what 1/100 and 1/200 is. Are these sections? Why wouldn't they both show - it is a dependent view!
Please explain.
PS If these are supposed to be callouts for your plans then you don't understand matchlines in Revit. They have a callout that does this autmatically depending on the view.
0 Posts No Rating |
Thanks for your help,
My problem is in partial plans, it showing. The tag of partial section overlapping the main section
Just I want to hide one of it
So???? Simply hide in the view where it should not show. This is one of those 'crossing the line issues'. The view will still show in the other view.
0 Posts No Rating |
Yes that's what I'm doing now
U r kind thaks for you
New Sub-Category for Different Sections |
Mon, Feb 23, 2009 at 3:46:21 PM
section tags for broken wall sections |
Fri, Dec 7, 2007 at 10:57:25 AM
section tags |
Fri, May 27, 2005 at 2:28:29 PM
Annotating Building Sections/Wall Sections/Details [ 1 2 ] |
Thu, Mar 17, 2011 at 2:54:40 PM
15
3D View Tag in plan |
Thu, Jul 25, 2013 at 4:24:45 PM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
