55 Users Online (53 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> Keyboard shortcut
Hi, I am new in Revit and XML. Can anyone help me, or point me where I can find information how to create new keyboard shortcut. It should be same as Detail Component shortcut, but to insert specific Detail Component. I suppose something needs to be changed/added in this code, but don't know what: <ShortcutItem Paths="Annotate>Detail; Create>Detail" Shortcuts="COM" CommandId="ID_OBJECTS_FAMDETAIL_a" CommandName="Detail Component; Detail Component"/> Name of component is _NE_Break Line 2 points
As I understand I would need to make new command that will look something like "Annotate>Detail>_NE_Break Line 2 points; Create>Detail>_NE_Break Line 2 points"
Thanks!
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
Keyboard shortcuts are found if you click the R button in the top left of Revit and then the options down the bottom of the window. Go to the User Interface Tab and click on the Keyboard Shortcuts button. Find your command and type in your shortcut using two letters. If the same two letters are assigned to another command already then a warning popup window will appear. Just take note of that command, go to it and change it to something else and then repeat your preferred command shortcut
Looking for quick Key shortcut |
Thu, Jul 2, 2009 at 10:22:19 AM
Some Keyboard shortcuts not working? |
Tue, May 5, 2009 at 2:52:55 PM
Exported Keyboard Shortcut file is .xml format - can't open in Excel |
Fri, Jan 13, 2012 at 11:41:37 AM
Keyboard Shortcuts |
Thu, Jan 20, 2005 at 5:15:30 PM
Use REVIT Shortcut Commands |
Wed, Mar 31, 2021 at 7:59:28 AM
Members: | 2022368 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
