67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Hiding finish line of wall in plan
Wed, Apr 1, 2015 at 6:18:13 AM | Hiding finish line of wall in plan
abilla
I have a 200 mm thick wall with 15 mm finish on wither sides. I dont want to see finish lines in plan but I need the finish surface in elevation. Somebody help plzzzz.
Wed, Apr 1, 2015 at 7:04:51 AM | Hiding finish line of wall in plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just make your wall 230mm thick and have the surface pattern be whatever your finish pattern is.  You could also set your detail level to course.
Breaking a Jogged Section Line - Hiding Central Portion
Thu, Aug 1, 2013 at 5:52:36 PM
Wall Finish
Wed, Aug 9, 2006 at 6:02:52 PM
Wall visibility Core/Finish
Tue, Jul 3, 2007 at 8:39:05 AM
Revit Arch 2015 - Wall - Hide a Wall Layer line
Tue, Oct 28, 2014 at 12:30:40 AM
Hiding walls
Sun, Apr 17, 2005 at 3:55:25 AM
Page generation time: 1.6978
