63 Users Online (62 Members):
Forums >> Revit Building >> Tips & Tricks >> Door Swing Angles
2 Posts No Rating |
I assume this is a simple question, but I haven't found the answer. How does one adjust the angle of opening for doors in plan? i.e. so the door shows as only open 45 degrees, or all the way around or whatever.
Thanks
Hola:
The way I have accomplished this task is modifying the lines on the plan view at the door family. The modification displays the door at a 45 degree angle. Once modified, I saved it adding 45 to the door family name.
I hope this works.
27 Posts No Rating |
There is an 'adjustable door' family on the RevitCity downloadable file libraries. It has parameters that let you set swing angles and other door properties - you can use this instead of a huge collection of doors - it's pretty cool!
2 Posts No Rating |
Thanks. I knew it was possible, and that this forum was quicker than re-inventing the wheel again.
5 Posts No Rating |
Here is a simple tutorial
![AbelGoddard Avatar](user_avatar/57678.jpg)
15 Posts No Rating |
Not so much a 'simple' tutorial. Several things not explained in it for the novice.
Helping you Be Able to be the person you want to be! Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com |
![coreed Avatar](user_avatar/14568.jpg)
maybe this give a little more info http://knowingwhatyoudontknow.blogspot.com/2008/01/adjusting-door-swings.html
2 Posts No Rating |
In this page there's a downloadable door with swing parameter.
http://cad-passion.webs.com/index.htm
Door swing with different angles in floor plans |
Mon, Aug 29, 2011 at 1:32:06 PM
11
Door Swing Question |
Mon, Oct 22, 2012 at 3:51:32 PM
12
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ] |
Tue, May 12, 2020 at 2:41:52 PM
16
Revit 2015 Curtain Wall-Offset Pivot-Single Door |
Thu, Aug 6, 2015 at 11:32:27 AM
Door Swing |
Thu, May 18, 2006 at 4:20:39 AM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
