68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> curtain grid angle
I have a single window where I need to make the curtain grid go at a angle..
So that the curtain grid goes from top left corner to bottom right corner..
How do you do that?
Post edited on 2006-03-21 06:30:40
209 Posts No Rating |
if you require on the outer edge of the curtain wall to be angled select the curtasin wall click edit and use sketch mode to get the desired angled. If you require the curtain grid to be angled inside the window then you can select the curtain wall - element properties you will see a parameter to set angles for the horizontal and vertical grids. If you need a bunch of random angles inside then you might want to either replace panels with an angled grid predefined panel or just break the window into many pieces use sketch mode to define the anlges and connect the pieces together then group them. Not sure what else you can do.
Edited on: Thu, Feb 12, 2009 at 1:46:24 PM
Curtain Wall Grid Angle |
Tue, Feb 15, 2011 at 2:42:32 PM
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain Grid Problems [ 1 2 ] |
Wed, Apr 10, 2013 at 5:57:45 AM
19
Curtain wall grid |
Sat, May 28, 2016 at 9:58:45 AM
changing grid lines angle - walls are detached |
Fri, Apr 20, 2007 at 6:29:43 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
