98 Users Online (97 Members):
Forums >> Revit Structure >> Technical Support >> Footing Problem with Blockouts
So, I was adding some blockouts to my wall panels for a project I'm working on, and it seems that if the blockout goes all the way to the edge of the panel, so that it's open on one side, then the footing automatically puts itself into the top edge of that blockout. Why does it do this? I've attached a screenshot of what I'm talking about. Thanks!
Sorry but that is the wal Revit works. Leave a tiny sliver of wall there... like 1/256" high.
WWHub thanks. I actually figured it out after looking around some more. Instead of editing the wall profile I used the wall opening tool and just did it that way and it seems to have solved the problem.
Double footing problem - plz help?? |
Thu, Nov 15, 2012 at 3:24:50 PM
Problem when applying a footing to wall |
Thu, Aug 23, 2012 at 1:58:50 PM
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
Concrete pad footing moves with steel column |
Thu, Dec 12, 2013 at 10:58:07 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
