61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Darker interior elevation boundary
Mon, Mar 20, 2006 at 3:32:02 PM | Darker interior elevation boundary
profbrody
I have drawn up some interior elevations, but want to make the boundaries darker - anyone know if this is a setting somewhere? I was thinking maybe the Crop Boundary could be made darker... also, can there be irregular boundaries?
Mon, Mar 20, 2006 at 6:13:16 PM | RE: Darker interior elevation boundary
eldados
eldados Avatar
4.5 Stars: 8 Votes
when you say boundaries darker, do you mean the line weight around your elevation? use the pen tool with a heavy line weight. and no you can't have irregular boundaries just yet Smile
Integrator
KarelCAD
Thu, Aug 30, 2007 at 1:38:55 PM | Darker interior elevation boundary
twhisker
2 Stars: 4 Votes
I just posted the same question and I just got my answer with a little fiddling and a hint from a friend.
 Select the boundary box.  right click and select Override Graphics In View (by category) change the line weight to a higher value.
BAMM - your boundary box is now a fat line for interior elevations!!
 Anyone know how to make this change permanent to either all projects as a system setting or at least to Interior elevation views?
Revit Architecture 2010
Thu, Aug 30, 2007 at 6:15:57 PM | Darker interior elevation boundary
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes you can in 2008 Smile
just don't forget to un-check the "Hide Crop boundaries" in your printer settings...
Integrator
KarelCAD
Mon, Nov 24, 2008 at 10:36:55 AM | Darker interior elevation boundary
jmqrsq
5 Stars: 3 Votes
How can you implement this to all interior elevations?????
Mon, Nov 24, 2008 at 11:25:11 AM | Darker interior elevation boundary
twhisker
2 Stars: 4 Votes
Unfortunately, you have to do this for each interiro elevation.  There is no global object settings for a crop boundary.  You need to select each views boundary - right click and select Override Graphics In View (by object - sorry I errored in my earlier explaination).  Then select a higher line weight.  You need to do this for every interiro elevation view which is a pain.  This ONLY works for a regular rectangular room.  if your room outline is irregular, you will need to create a masking region for the room perimeter.
Mon, Nov 24, 2008 at 11:47:54 AM | Darker interior elevation boundary
jmqrsq
5 Stars: 3 Votes
Thanks. that is what I have been doing. When I saw the moderators comment of "2008" and being able to I got a bit excited that maybe i had missed something. =) thanks
Interior Elevations - darker irregular boundary lines
Wed, Oct 1, 2008 at 12:55:15 PM
Darker Interior Elevation Boundary Lines
Thu, Aug 30, 2007 at 2:05:59 PM
Mon, Nov 24, 2008 at 10:35:26 AM
elevation crop boundaries
Fri, Jun 6, 2008 at 5:08:18 PM
Revit 2013- Adjusting the default setting for Interior Elevation crop boundary?
Mon, Aug 26, 2013 at 4:23:48 PM
Page generation time: 0.4929
