129 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Down Loading Familys
Sun, Mar 22, 2015 at 1:25:59 PM | Down Loading Familys
RooRoo
Revit 2015:
A resent update has created a situation that causes a second vertion of revit to open when I down load a new  family from the internet.  Then I can not load it directly into my current project since two vertions of revit are running at the same time.  I can save the family, and open  reload it with the vertion nthat my project is on....., but it takes additinal time.
Why is this happening?
Sun, Mar 22, 2015 at 9:31:35 PM | Down Loading Familys
raja15
I'm having the exact same issue when opening revit families/projects through our server.
I know it has been mentioned before about it's best to open the project/family via the "Revit window" rather than through "My computer" etc, however I have had no issues with this up until the recent update as well.
In the meantime I'm adjusting to opening files via the "Revit window" , however it is still frustrating when, as you say, you go to open a downloaded file and it opens a new revit window not allowing you to load into the project you had open.
Any advice or feedback?
Is this a problem with all users who have the latest update? (Update Version 5)
Mon, Mar 23, 2015 at 7:50:43 AM | Down Loading Familys
Autodesk has always said "DON'T START REVIT BY DOUBLE CLICKING ON A FILE".  If you follow that advice, there is no way that "... you go to open a downloaded file and it opens a new revit window ...."
RooRoo,  I don't have a problem using 2015 "
20150127_0715(x64)Update Release 6
Tue, Mar 24, 2015 at 5:45:49 PM | Down Loading Familys
raja15
WWHub - we are aware that autodesk has said to not open a file by "double-clicking" on it, however this is the only way we are able to open revit currently.  For some reason the program is not able to be accessed by opening it stand-alone.
We've scheduled in to download the update sometime today, hopefully something that will resolve these issues we are having.
Thanks for passing on that the update is available.
Books on making revit familys
Thu, Feb 23, 2006 at 10:06:57 PM
Help turning off Familys
Thu, Sep 20, 2007 at 12:53:12 AM
Line Based Familys
Fri, Aug 3, 2007 at 12:06:54 PM
LOADING COMPONENT [ 1 2 ]
Sat, Apr 11, 2009 at 5:30:14 AM
24
Problem loading components
Mon, Sep 28, 2009 at 3:43:41 AM
Page generation time: 0.5161
