31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Creating Room Tags with shared parameters
Wed, Mar 18, 2015 at 6:50:41 PM | Creating Room Tags with shared parameters
Kristian13
Hi all,
I am trying to create a room tag that uses shared yes/no parameters to control the visibility of the labels.
I have created the shared parameters in the parameter file, but i cant load them into the family, as in I cant assign them to any labels. The options are always greyed out.
Am i doing something wrong, or is this not a possibility?
I'm using Revit 2015.
Cheers,
Kristian
Wed, Mar 18, 2015 at 7:05:46 PM | Creating Room Tags with shared parameters
Kristian13
Let me elaborate further.
The room tag is set up with about 7 labels which each control different elements, such as name, area, occupancy, etc.
I want to swap out the current Occupancy parameter (which is not a shared parameter) with one that is a shared parameter.
Further to this, if at all possible, i want to make the shared parameter instance based. I have the same Occupancy parameter in the project parameters as well to link to.
Cheers,
Kristian
Wed, May 20, 2015 at 8:33:45 AM | Creating Room Tags with shared parameters
Savidge
Bump.
I am having some similar issues with room tag shared parameters as well, anyone else have experience with this?
Best,
Nate
Wed, May 20, 2015 at 8:56:15 AM | Creating Room Tags with shared parameters
Savidge,   Ask a complete question with specifics.
Kirstian's question said here tag's occupancy was not a shared parameter.  That can not be true since only shared parameters can be included in tags.   << So that can't be your problem either.
Wed, May 20, 2015 at 11:56:07 AM | Creating Room Tags with shared parameters
Savidge
My mistake,
My error was unrelated, I misread the original post
Room Shared Parameters
Tue, Sep 18, 2007 at 9:33:21 AM
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Creating Shared Parameters
Tue, Nov 25, 2008 at 4:45:08 AM
Version 2009 - Shared Parameters and Key Schedules
Fri, Jan 30, 2009 at 1:49:25 PM
Page generation time: 5.1515
