72 Users Online (70 Members):
Forums >> Workflow & Implementation >> Hardware >> Revit Structure 2014 - Jerky / Slow - why?
I'm using Revit Structure 2014 and have a persistant issue - regardless of the size of the model I'm working on or what I'm doing every ~8 seconds or so the cursor will go into 'hourglass' mode for a second. It does this regardless of what I'm doing - moving the cursor around a plan view, selecting items, editing items, in 3D mode or looking at a section. Even if I just move the cursor from one location to another in blank space without touching any building elements. It also happens regardless of the model size I'm working on - at the moment I'm in a ~50MB model, so it's not exactly pushing the boundaries of the system I'm using.
As far as performance goes - I have
16GB of Ram
Quad core 3.7 GHz Intel Xeon E5-1620 V2 processor
AMDfirepro w5000 (firegl v) graphics card.
Has anyone else had this issue? What might cause it?
This may be a network problem. Are you working in a work shared model? If so, look at your worksharing update frequency under the Revet R dropdown/options. If you change that frequency, does it change the frequency of your problem? If so, then the issue is your network.
Thank you - problem solved.
The worksharing was set to every 5 seconds (I guess I counted too fast to get the 8s before), I changed it to 30seconds and the pause happened every 30s.
Revit Structure Lt or Full Version? |
Tue, Sep 10, 2013 at 8:25:18 AM
Cursor not visible in schedules, Revit Structure 2014 |
Tue, Apr 29, 2014 at 2:16:15 PM
Slow performance Revit 2014 XenDesktop |
Mon, Oct 20, 2014 at 3:50:13 AM
Unable to start robot analysis structure (HELP NEEDED) |
Tue, Apr 29, 2014 at 10:11:09 AM
SDS/2 Connect Now Available For Revit Structure 2014! |
Wed, Aug 7, 2013 at 2:11:19 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
