45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Show two cut/ fill patterns in on wall
Revit 2015
My company's office standards are existing walls no shade. New walls solid fill on grey color or screen. We also show the hatching of a wall if its masonry (CMU, Brick). So there are times when I need two things to show up in a wall cut pattern. Ex. New CMU wall should be shaded (poche) and also have the cross hatching.
I've looked all around and experimented with different phasing. If you over ride a phase to show the solid fill poche it takes away the wall construction cut fill (cross hatch) I cannot get both to show up. Ive tried different detail levels as well. Any help would be great!! Thanks in advance!
Sorry but this is one of those instances where your office standards will need to change. You can not have two fill patterns applied to the same material and you don't want to do this manually. We usually show existing with no fill but lighter wall lines using phases and new with wall appropriate material hatches.
![blue442 Avatar](user_avatar/119111.jpg)
We dealt with this on a renovation of a house. We created a large filled pattern that traced where the existing house was and was not being touched. We still wanted the exterior of the skin to be hatched like brick where it remained. This obviously won't work if you just want the walls grey and the spaces white... but this method worked for us.
wall fill patterns for different wall types and phases |
Sun, Apr 24, 2016 at 4:42:58 AM
Wall cut patterns |
Fri, Jun 16, 2006 at 1:29:23 PM
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Wall Fill Pattern question |
Tue, Oct 23, 2012 at 8:39:37 AM
Revit 2015 Solid Cut Fill Pattern |
Thu, Sep 22, 2016 at 8:27:54 AM
Members: | 2016882 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
