Forums >> Revit Building >> Technical Support >> Duplicating Floor Plans (Revit 2015)
0 Posts No Rating |
I am making a set of drawings and want to be able to duplicate my original floor plan and then edit/delete/add things to the duplicated floor plan. However, when I duplicate it and make the changes to the duplicate it also changes the original floor plan. Is there a way to keep my original the way it is and make changes to the duplicate? For example, I would like to end up with an overall floor plan, enlarged floor plans for certain areas, finish plan, etc.
I appreciate the help
You duplicated as dependent - Don't do that in your case.
Use either duplicate or duplicate with detailing. Dependent is best used with plans that have match lines.
Another option is to use the plan pulldown and uncheck the 'do not duplicate' box. This will give you a plan without any detailing.
0 Posts No Rating |
I have tried all the different duplicating options and every way I try (duplicate, dependant, detailing) still makes the same changes to the original that I make to the duplicate.
Now I believe I understand but you are still not clear. You are talking about model elements and I am talking about detail/annotative elements.
This is Revit and the main model is shown in all views. If you want to have different model 'options' in different views, then you need to use design options. You can read about those here:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-D48B1E7E-BC34-414E-85BD-790F199BB2C0
You then need to set up the VG in your copied views to show which option you want to show in that view.
Duplicating a floor plan and Creating a new floor plan |
Wed, Feb 3, 2016 at 7:28:16 AM
Enlarge Floor Plans |
Thu, Feb 12, 2009 at 4:12:21 PM
12
Best Software to Create Presentation Floor Plans |
Fri, Apr 30, 2010 at 12:56:47 AM
Using Area Plans as Main Floor and Unit Layout plans |
Mon, Mar 29, 2021 at 1:59:33 PM
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS |
Mon, Mar 5, 2007 at 2:39:54 PM
Members: | 2114972 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
