Forums >> Community >> Newbies >> Downloading and using families
I want to draw a basketball court on revit. I downloaded the basketball hoop from this site but the hoop is too big. How do you change the size of it? The dimensions box is empty
Which one, and what dimension do you want to change?
http://www.revitcity.com/downloads.php?action=view&object_id=5095
this is the one I'm using. I need to change pretty much all the dimensions to fit my drawing
also is there any way to sort the newly downloaded objects? when i place the file into the library folder and load it in the drawing, it seems to appear in a random spot in the list
Edited on: Fri, Feb 27, 2015 at 8:38:01 PM
The family is not parametric, it cannot be changed by just entering the dimensions. You can either, look for a different one – parametric, or you can play with the one you have, it’s a pretty simple family. The pole is a sweep, the hoop is a blend and the backboard is an extrusion. All these elements can be modified separately in the family to suit your needs.
Families not downloading |
Mon, Mar 5, 2007 at 6:13:46 PM
downloading families from RevitCity |
Thu, Mar 1, 2007 at 3:57:31 PM
DOWNLOADING FAMILIES |
Wed, Apr 19, 2006 at 6:47:46 AM
downloading patterns |
Thu, Jun 8, 2006 at 11:56:47 PM
Downloading? |
Wed, Jun 5, 2013 at 10:15:23 PM
Members: | 2104250 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
