60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Double-side elevation marker where one is the reference of another
1 Posts No Rating |
So this might be a silly problem, but it seems ridiculous that it can't be done. I have a hallway with two doors into apartments opposite one another. We are building custom door surrounds for each, so on surround is a perfect mirror image of the other. So it makes sense to do an elevation of one, and have the other just be a reference elevation. However, instead of having two elevation markers side-by-side (which looks sloppy and wastes space) I'd rather just use the option that adds a second arrow to the same symbol. HOWEVER, you cannot do this and have one of the arrows be a reference elevation, because you have to choose to make it a reference elevation BEFORE you add the arrow. So is there any way to do this how I want?
Edited on: Thu, Feb 26, 2015 at 9:19:06 AM
Edited on: Thu, Feb 26, 2015 at 9:25:34 AM
Edited on: Thu, Feb 26, 2015 at 9:26:18 AM
Cut a new elevation using the reference other view and drag the callout on top of the other one.
Adding a reference elevation to an existing elevation marker? |
Wed, Sep 17, 2014 at 7:57:46 AM
Split a an elevation marker up for mulitple sheets |
Tue, Oct 4, 2016 at 2:29:34 PM
ELEVATION MARKER |
Thu, Sep 10, 2009 at 2:55:39 PM
detail Marker |
Tue, Sep 16, 2008 at 10:30:09 AM
If your elevation markers on plan disappear. |
Fri, Mar 4, 2016 at 3:40:45 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
