39 Users Online (38 Members):
Forums >> Revit Building >> Tips & Tricks >> Section Details
0 Posts No Rating |
Hi all,
I used to think the best way to do my slab-wall joint detail was to do a call out, work in this raw section as a template and add detail items as needed. But the joint slab multi-layer in revit isn't accurate to this scale level, and i end up having a bunch of lines that makes my detail confusing.
I guess it's better just to do typical drafting details non reference to a specific joint....? Any thoughts?
Please share an image of what you are talking about.
BTW. I have never seen Revit not accurate at any scale.
0 Posts No Rating |
I usually do call out, blow up scale and fill in with detail items.
I figure out with the 'switch order of joint tool' the way to create the junction properly.
I just wonder if this is the way Revit is inteded to do the construction details or i should do a complete drafting view all with detail elements...?
"....or i should do a complete drafting view all with detail elements...?..." Absolutly Not!
Have you even heard about this process? http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-BE871A38-C99F-4D07-93B5-576CEBA0E68D
With that, you can use most of your model elements. No need for filled regions! And your geometry will be correct.
Use detail elements for finer detailing. So a wall section at a window uses the model wall maybe with edit cut profile on some of the layers and add a window head & sill detail component. Typically that may be all.. maybe some blocking detail elements and linework for air/moisture barrier. Since this is a model section, your wall / fllor / ceiling tags all work and so do material tags. Why would anyone want to do drafting details? NOT ME!
Details |
Thu, Aug 4, 2005 at 4:40:33 PM
Section Blow up Details |
Tue, Apr 29, 2008 at 4:38:22 PM
Callouts/Details |
Fri, Jan 25, 2008 at 4:01:11 PM
query with elevation details |
Mon, Dec 1, 2008 at 5:12:35 AM
Using 2d group for Wall section, section details called out from wall section? |
Fri, Oct 9, 2015 at 10:50:56 AM
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
