164 Users Online (163 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls used as curtain panels - stop joining
Fri, Feb 20, 2015 at 4:27:47 AM | Walls used as curtain panels - stop joining
awasyliw
I have a small issue I'm grappling with.
I have a curtain wall which uses a normal wall style as an infill panel (yes I know, it's not ideal, but sometimes necessary). My problem is that even if the curtain wall is set to disallow join, the 'wall as curtain panel' still joins to the adjacent normal walls (which I do not want as its throwing my wall joins out). The 'wall as curtain panel' does not display any end points to enable me to right click and disallow joins.
Anyone have any experiecne with this?
Fri, Feb 20, 2015 at 10:32:10 AM | Walls used as curtain panels - stop joining
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
can you post an image of your problem?
Fri, Feb 20, 2015 at 11:01:41 AM | Walls used as curtain panels - stop joining
This may not be the best answer but if you place your curtainwall in a design option, it will not join with your main model walls.
Just retested this and the results are not always predictable.
Edited on: Fri, Feb 20, 2015 at 11:08:15 AM
Mon, Feb 23, 2015 at 6:40:09 AM | Walls used as curtain panels - stop joining
awasyliw
For reference, I didn't find a way to do exactly what I wanted, but I resolved it by adding another curtain wall gridline 2mm from end, and changing thew last panel to a standard solid, this stopped the wall joins happening. Not perfect, but worked.
Guess I ought to look for a few more unitised curtain wall panel families, but there just don't seem to be many good ones around, and I don't have time to build them.
Anyone got any tips for converting a normal window or door family to a curtain wall panel without just rebuilding the whole thing? ... I realise this is not just a straightforward thing to do.
Mon, Feb 23, 2015 at 8:14:14 AM | Walls used as curtain panels - stop joining
Why would you do what you ask?  You already have curtain wall doors that can easily be modified and there are operable windows on Autodesk Seek that work in curtain wall systems.
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:02 PM
Keeping walls from snapping
Fri, Jul 21, 2006 at 12:06:04 PM
Curtain wall panels with an arrayed profile
Thu, Mar 13, 2014 at 3:02:36 PM
joining curtain walls
Mon, Jun 7, 2010 at 10:52:22 AM
Can Adaptive Panels Be Used in A Curtain Wall
Mon, Jun 9, 2014 at 1:49:37 PM
Page generation time: 1.0669
