Forums >> Revit Building >> Technical Support >> View Range Revit 2014
0 Posts No Rating |
Hi,
I have some open to below spaces on my floor plan 1. I have set underlay none, view range associated level (offset 0') for bottom and view depth. And still I can see the stuff that's below on the opening. I don't know were else to modify settings..
Thanks,
You would need to tell us more. What is "... I can see the stuff that's below on the opening..."? Images - descriptions will help.
If you have any non-cuttable objects that are cut by the view plane, then those items will show completely. Search cuttable in your HELP.
0 Posts No Rating |
I have a stair from Level cellar to level 1. On level 1 i want the stair to be cut, not showing full.
Thanks,
That's not going to happen - sorry. This has always been a problem in Revit with one story stairs from the level below.
0 Posts No Rating |
ahhh ok Thanks anyway
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
Revit MEP 2012-View Range |
Fri, Apr 12, 2013 at 7:22:48 AM
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
I can not figure out teh "View Range" in revit 2013 |
Fri, Aug 30, 2013 at 12:54:18 PM
Members: | 2104993 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
