53 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Advanced Family Modeling
I am in the process of creating some casework families with several parameters and creating type catalogs for these families. Is there a way to include Visibility (Yes/No) parameters in a type catalog?
Second, when specifying a formula for Yes/No parameters is there a way to specify a range for the parameter to be on (24"<Height<30" or is it simply a limit (Height<30"?
Finally, is there a way to use conditional Formatting in Yes/No Parameters? I tried several ways to format it but it either gives me an error for inconsistant units or an error for an unspecified family. Of those formats I have tried using "yes"/"no", 0/1, +/-, "true"/"false", and "t"/"f" for the output.
Any help or insights into this would be greatly appreciated.
Yes/No parameters do not need conditional statements in order function.
When adding a formula to a Yes/No parameter if the formula is true, its yes, otherwise it will be set as no.
For instance:
Height<30" is sufficient. Therefore if the height was say 26" the visibility would be Yes.
Not sure about using them in type catalogues, never tried...
I guess you could try: (where Visibility param is the name of your Yes/No Param)
,Visibility param##other##Millimeters
Then when listing each type set the value as blank or "visibility param"?? Not sure on this bit... May require some experimenting.
HTH.
the most advanced parametric family??? |
Thu, Sep 8, 2005 at 10:02:36 PM
Modeling a family outside of Revit |
Mon, Dec 19, 2005 at 11:39:34 PM
Advanced Conceptual Massing Help |
Tue, Aug 28, 2012 at 11:58:53 PM
Family Modeling |
Mon, Sep 8, 2008 at 11:49:44 AM
Was hoping to find some common advanced framing details |
Wed, Jul 13, 2016 at 4:20:20 PM
Members: | 2017212 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
