130 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Area Tags - Rounding refuses to change
Tue, Feb 10, 2015 at 6:19:03 PM | Area Tags - Rounding refuses to change
Kristian13
Hi all,
I have inherited a project which has been butchered by the previous people who worked on it, so forgive me if im not super helpful with how it has been set up.
My problem is relating to area tags, and the way that they round up the figures.
My project units are set at rounding = 0
The area tag is also set to rounding = 0
If i change 1 or both of these to display as Rounding = 2 decimal places, the actual area figure shown on my area plans does not change.
Am i doing something wrong, or  is my area tag family just really really bad?
Any help or advice is much appreciated,
Kristian
Tue, Feb 10, 2015 at 6:59:16 PM | Area Tags - Rounding refuses to change
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In the tag family, select the area label and click on edit label. In the dialog box (see pic), if you check ‘use project settings’, the label will do exactly that. Or, you can uncheck it, enter your values and they will take precedence in the project.
Tue, Feb 10, 2015 at 8:22:13 PM | Area Tags - Rounding refuses to change
Kristian13
Perfect! pijpiwo to the rescue once again.
Thank you!
Rounding in Formulas
Wed, Mar 13, 2013 at 8:49:48 AM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
AREA SCHEDULES ROUNDING TO THE NEAREST
Wed, Dec 20, 2006 at 4:36:48 PM
incompatible area tags
Sat, Jan 14, 2006 at 1:57:46 AM
Rounding Issue in Schedules
Mon, Jan 9, 2017 at 2:07:07 PM
Page generation time: 2.4541
