43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Revit 2015 Crashes when attemptiing to save to central
Good day all,
We're using Revit 2015. There are no problems working with the model until attempting to save to the central file. It then throws an error, crashes, and exits the program.
I've tried installing all the Autodesk updates and making sure that the OS is up to date. Attached is a sample from the journal leading up to the crash. Any input would be greatly appreciated. Thanks in advance!
Not sure if this helps but our office is having the same problem when we go to print.
Same thing, we have installed all the updates, it's just when we go to File>Print the entire window freezes and crashes on us.
I'm now wondering if this is happening to other offices as well ?
If both of you have the latest updates and drivers installed, then you need to contact your reseller.
We are not seeing these complaints here so it is something unique to you and your systems.
I'm having these problems with saving locally but not synchronizing to central.
Running fully updated Revit 2015.
can't save as a central file |
Wed, Sep 9, 2009 at 2:35:47 PM
save central |
Wed, Apr 8, 2009 at 9:02:46 AM
Central Model File locations - clouds Revit Arch 2015 |
Wed, Dec 6, 2017 at 10:10:53 AM
Error..wouldn't let me save to Central...help needed |
Wed, Feb 28, 2007 at 9:48:56 AM
Can't share central file |
Mon, Nov 23, 2009 at 4:07:18 PM
Members: | 2037326 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
