107 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Alinged Dimensions
Thu, Mar 16, 2006 at 11:32:16 AM | Alinged Dimensions
hammer87
hammer87 Avatar
3 Stars: 4 Votes
is there a way to find the lenght of one side of the roof? or a way to do an alinged dimension
Thu, Mar 16, 2006 at 11:59:29 AM | RE: Alinged Dimensions
archdan
3.5 Stars: 2 Votes
There a few ways I can think of doing this. If the roof edge is cut perpendicular (not plumb cut) to the roof face, you could string a dimension from the roof edge to a point at the peak of the roof (press tab until a single dot appears at the ridge). If that doesn't work, try drawing reference lines or planes perpendicular to the face of the roof and copy the lines/planes to the peak and string dimensions between the two lines/planes.
Thu, Mar 16, 2006 at 12:00:37 PM | RE: Alinged Dimensions
arccodex1
3 Stars: 1 Votes
Select the dimension tool Tab through the elements until you get a POINT Click on the point Do the same with another point and you have yourself a dimension aligned between two points.
Thu, Mar 16, 2006 at 1:20:28 PM | RE: Alinged Dimensions
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ill have to try that, since what we have to do is build a fom model of one of our projects
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:37 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:53 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:57 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:52 AM
Page generation time: 0.4034
