76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Timber Frame Roo
Sun, Feb 8, 2015 at 9:42:34 AM | Timber Frame Roo
sultanmimar
Hi everyone,
I am a student.We have a class about timber roof structure.I need to design timber roof and get detail drawing,workshop drawings.I am using revit 2015.It has extensions of rafter framing,frame generator,roof trussess.However I don't know how to use it,how to get workshop drawing because in the internet(youtube) there isn't enough tutoriols about this.When I make a small research on the internet,I see an extension ,AGA-CAD wood framing .Most of tutorials about the issue tells this AGA-CAD wood framing extension.
               I want to what is the most logical way to model timber roof and crate workshop drawings.Thank you...
Thu, Feb 12, 2015 at 12:45:24 PM | Timber Frame Roo
Ranger57
AGA-CAD have a great add on for that, but it will cost you. An alternative would be to use beam systems and rotate and shape to suit.
Thu, Feb 12, 2015 at 3:10:17 PM | Timber Frame Roo
You can use structural families but you may need to learn a lot more.
If this is not BIM, then I would be tempted to create each timber fame as one, modeled-in-place bent built on a work plane.  Just one simple extrusion if it is all same thickness.  Then add the other direction timbers as another model-in-place family.  If this is a square structure with no mi-bents, that would be 4 famlies.
This user is online
Fri, Feb 20, 2015 at 4:00:54 AM | Timber Frame Roo
vincente
Right, AGA-CAD is great one, been using it.
timber frame valleys
Wed, Apr 18, 2007 at 3:07:00 PM
timber frame panels
Thu, Jan 12, 2012 at 11:09:38 AM
Timber Framing
Tue, May 9, 2006 at 9:04:40 AM
Timber framing in Revit?
Tue, May 18, 2004 at 11:46:23 AM
How would I go about creating a timber frame?
Fri, Feb 10, 2006 at 3:49:51 PM
Page generation time: 1.6594
