70 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Spanish Style Tile Roof
Thu, Mar 16, 2006 at 8:56:07 AM | Spanish Style Tile Roof
jweber
Has anyone ever created a Spanish Style Tile roof? I am getting ready to start one and would like suggestions. I am attaching a photo of what I am looking for. Any help on the process would be appreciated. Thanks. J
Thu, Mar 16, 2006 at 9:44:03 AM | RE: Spanish Style Tile Roof
JSavage
1 Stars: 1 Votes
I experimented with this a few months back using Sloped Glazing... I created the tiles by creating two different mullion types (using a custom profile, turned 180degs from each other) and set the cutain panels as 'empty'. Set the curtain grid to the appropriate width and away you go. Its not a perfect method, but looks quite effective for elevations and medium distance 3D views and means you can control the roof as you would normally. Beware though, as you'll probably get a big performance hit with that many tiles flying around. Good luck
Sat, Mar 18, 2006 at 9:53:03 AM | RE: Spanish Style Tile Roof
carlosgt
There must be any way to create a new pattern for the roof (barrel tile or spanish tile) so, instead of shingles pattern (normally used) we could assign this new pattern to the roof. I have been trying to create the same spanish style too. I appreciate if you let us know if you have any others ideas. Thanks. Carlos
Sat, Mar 18, 2006 at 10:09:18 PM | RE: Spanish Style Tile Roof
FlyinHigh
1 Stars: 1 Votes
I did do this late last year for a school project for a competition. Check out Got3D.com for a pattern, or just google a picture of the tiles. Save the picture. Create a normal roof and then go to properties, then to edit/new, then click on the roof material. You will see another arrow for rendering texture, click on this. From here you will be able to choose Material, Create New, Default Material. Then go to the maps tab and add the material. You may have to create a new library to save this material under though. Once all is said and done you may want to do a region raytrace to double check everything. If you have any trouble just post another reply and ill see what i can do.
Mon, Mar 20, 2006 at 9:09:20 AM | RE: Spanish Style Tile Roof
eepa
5 Stars: 2 Votes
This is an interesting question! Up!
Mon, Mar 20, 2006 at 11:51:28 AM | RE: Spanish Style Tile Roof
apacis
carlosgt has a point in using hatch patterns for the graphic effect of a spanish style roof - is uses less machine resources and gets you to show enough information needed for construction documentation. I have a hatch pattern I am applying as a model pattern but somehow I do not have control of the scale. Here it is...what can you suggest?
Tue, Mar 21, 2006 at 2:40:23 PM | RE: Spanish Style Tile Roof
arccodex1
3 Stars: 1 Votes
I know, the Import Scale is greyed out right? Just click once on the new pattern spanish2. The Import Scale is now editable.
Tue, Mar 21, 2006 at 3:56:24 PM | RE: Spanish Style Tile Roof
carlosgt
OK, this what I did to create my spanish roof tile. I download a new fill pattern from the family pattern in this web site. You can find a few ones, like "barrel tile", "clay roof", etc. After I saved the file (*.pat) in my C drive, I load it in revit going to settings_fill pattern (click in model), edit_(click in custom)_import and go to the file *.pat you downloaded before. (you can change the scale of the pattern just click in the pattern and change the scale. And that is it. Then you can assing this new pattern to any roof. Carlos
Tue, Apr 24, 2012 at 3:49:34 PM | Spanish Style Tile Roof
ghost16383
4.5 Stars: 2 Votes
Agree with JSavage,
It works like a charm. i also use that method to create rafter and purlin system too and working well.
Wed, Aug 1, 2012 at 1:46:51 PM | Spanish Style Tile Roof
Stevearchman
ghost16383  can you provide step by step instructions for creating the Spanish tile roof shown in your post.  Your image file is more detailed than jweber's which shows a simple extrusion witout the segments.
Wed, Jul 17, 2013 at 2:15:22 AM | Spanish Style Tile Roof
#11
axdadmin
the pat file is unable to open how to use it???
also i would like to open the file in 3d view(hidden). 'll it be viewable ??
Thu, Jul 18, 2013 at 1:50:04 AM | axdadmin
#12
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting axdadmin from 2013-07-17 02:15:21
you have to apply pat file to surface pattern of roof material.
want more?
You can get more tips at Enjoy Revit
Thu, Jul 18, 2013 at 11:53:39 AM | Spanish Style Tile Roof
#13
AnejoDave
You can model the roof as a mass, divide the surface and apply a component to the face.  Now you have a Spanish tile roof.  Apply your chosen material and look like a Revit god.  Use your newfound glory only for good.
Use "Hide in View" and you're a nazi terrorist who takes the last beer
Mon, Aug 12, 2013 at 2:19:06 AM | Spanish Style Tile Roof
#14
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
I developed two different ways to make & palce spanish roof tiles.
http://www.youtube.com/watch?v=P-1NnkFC3fU&feature=share&list=UUaKybYEb-69SZZGdN-iMudg
http://youtu.be/JV4sVKH2Xns
But i think just few people need this. it's too heavy.
want more?
Spanish Roof Tile (tutorial video)
Wed, Sep 4, 2013 at 10:31:19 PM
Spnish Roof Tile generator
Thu, Feb 26, 2015 at 3:51:44 AM
Spanish Barrel Tile Model Fill Pattern
Wed, Apr 18, 2012 at 12:56:23 PM
Spanish Roof
Thu, Feb 28, 2013 at 11:40:12 AM
Roofing Design & materials
Tue, Mar 23, 2010 at 3:28:58 PM
Page generation time: 2.0641
