69 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> walls greyed out
Thu, Feb 5, 2015 at 12:35:08 PM | walls greyed out
jmuratore
Not really a question, cause I think I got it figured, but ...file this under Steve Staffords dept of quirky:
Some walls are greyed out. nearby walls of the same type, same height, same phasing (no worksets) show normal.
Walls are on two distinct slabs at same level. If I hide the floor underneath the "grey" walls they go back to normal.
I checked the element overides for that floor and I had somewhere along the line set surface transparency to 40%.
When I set that back to 0% everything shows normally. N.B. THIS IS A FLOOR *UNDER* THE CUT PLANE AFFECTING VISIBILITY OF WALLS ABOVE THAT FLOOR.
I forgot to mention that I have the cut plane at 8' to get fire tape / wall filters through door openings.
On Revit 2015, 20150127_0715(x64)Update Release 6
Mon, Jul 6, 2015 at 12:57:21 PM | walls greyed out
marscreature
4.5 Stars: 3 Votes
No idea for an answer, but im curious as to what you think you got figured out about the issue and how it came to be.
Mon, Jul 6, 2015 at 1:28:48 PM | walls greyed out
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
What are the specs on your computer for a graphics card?  Sometimes ATI or nVidia fight with the onboard i7 graphics processor.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Walls are greyed out
Fri, Dec 14, 2012 at 6:55:18 AM
Walls greyed out in PLAN VIEWS
Fri, Feb 19, 2016 at 4:32:58 PM
Half Revit model greyed out in 3d mode
Wed, Jan 30, 2013 at 2:20:46 PM
plotting greyed out title blocks??
Fri, Jun 9, 2006 at 8:46:11 AM
Render options greyed out
Wed, Jul 3, 2019 at 11:17:24 AM
Page generation time: 1.3941
