91 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> un-join walls
Wed, Mar 15, 2006 at 5:43:17 PM | un-join walls
jeffericson
So I want to slide one portion of a room out of the envelope. I split the long exterior wall, then select the split portion and move it. It drags everything, including the portion of wall I split off. Ctrl-Z. Unjoin Geometry doesn't do anything. It seems my only option is to delete the wall I'm trying to drag or copy it and trim both (if I've already got windows, etc. embedded). I run into this often. Is there any way to un-join an object from those around it? This method seems inefficient. Thanks in advance... Jeff
Wed, Mar 15, 2006 at 6:16:10 PM | RE: un-join walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When moving check the disjoin option...
Wed, Mar 15, 2006 at 6:29:53 PM | RE: un-join walls
jeffericson
I knew it was something simple... Thanks
walls overlap but dont join.
Sat, Jul 30, 2016 at 5:13:58 PM
90degree wall join
Sun, Aug 20, 2006 at 9:08:54 PM
When you can't make all walls join correct, what you do? [ 1 2 ]
Wed, Oct 7, 2015 at 2:15:30 PM
15
Join 2 roofs, like joining 2 walls
Wed, Nov 10, 2010 at 7:23:34 AM
join all walls with floors toguether ?? easy way?
Tue, Oct 17, 2017 at 2:50:57 PM
Page generation time: 0.5814
