56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> cut pattern issue
Wed, Jan 28, 2015 at 3:38:11 PM | cut pattern issue
ledgewood33
I have a diagnal line drafting pattern as my cut pattern for the cmu material. when I have walls that are not at 90 degrees to the screen the cut pattern stays at the same angle. I would like to have the cut pattern rotate based on the angle of the wall?
I have attached a screen shot of what I am describing.
Wed, Jan 28, 2015 at 3:53:15 PM | cut pattern issue
3.5 Stars: 397 Votes
Best answer is always to look in your HELP first:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-02C84BD3-8CFC-40D4-8E21-A195A3C0BB2B
Cut Pattern for Curtain Panel Not Showing in Plan
Fri, Sep 5, 2014 at 6:25:57 PM
loss of cut pattern
Fri, Nov 28, 2014 at 8:47:10 AM
ARCHITECTURAL COLUMN ISSUE
Thu, Feb 13, 2014 at 8:50:50 PM
Cut Pattern Issue
Fri, Jul 2, 2010 at 3:30:55 PM
Stiar cut pattern or fill pattern.
Sun, Feb 19, 2006 at 11:46:36 PM
Page generation time: 0.6440
