83 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> when i turn on my room's interior fill, i get an unwanted blue outline
27 Posts No Rating |
when i turn on my room's interior fill, i get an unwanted blue outline, how do i remove this? i need to turn on the interior fill so that the filters that i have set up (and applied to the rooms in the view) will show.
please see attached images which shows the comparison between 'with room interior fill turned OFF' and 'with room interior fill turned ON'. as you can see, when it is turned on, i get the desired interior fill for the filter in the rooms, however i also get a blue outline
i am using revit architecture 2014
cheers
This is something you have done because this is not the normal process. Show us your filters.
Revit 2014 - Room Boundaries as Lines |
Tue, Nov 19, 2013 at 6:57:18 AM
Fill Region Not Showing |
Wed, Aug 22, 2018 at 5:28:47 PM
Interior Elevation Bold Outline - Revit 2009 |
Tue, Mar 14, 2017 at 2:56:00 PM
Create an outline around a room |
Mon, Nov 4, 2013 at 11:57:18 PM
Can't create room name in revised room |
Fri, Jun 24, 2016 at 7:21:10 AM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
