53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Different color backgrounds with text.
Fri, Jan 23, 2015 at 12:49:04 PM | Different color backgrounds with text.
Pikachu123
is there a way to change the background color of a text?
Fri, Jan 23, 2015 at 12:52:59 PM | Different color backgrounds with text.
Pikachu123
I am using Revit 15, and it seems crazy to me that there isn't an option to change that, i tried copy and pasting from word, and that doesn't work. And making a color filled region seems a little excessive to have to do everytime i need to label anything that regards to a chilled water piping run.
Fri, Jan 23, 2015 at 1:08:53 PM | Different color backgrounds with text.
3.5 Stars: 395 Votes
Why not colored text instead?
Fri, Jan 23, 2015 at 7:57:37 PM | Different color backgrounds with text.
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It’s not a perfect solution, but hopefully it will make a life a bit easier.
Tue, Jan 27, 2015 at 7:10:46 AM | Different color backgrounds with text.
Pikachu123
No thats actually pretty sweet. Just different color fills with a Yes/No parameter named after the color.
But i cannot do just different color text, because its in the contract's specifications. Thanks pijpiwo. I'll take the concect, and match my spec to it. appreciate it man.
Tue, Jan 27, 2015 at 9:35:02 AM | Different color backgrounds with text.
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You’re welcome!
The file is just an example, feel free to modify it any way you want it. I’m glad you found it useful J.
Tue, Jan 27, 2015 at 9:44:11 AM | Different color backgrounds with text.
Pikachu123
Yea def is. thank you kindly. you would think that would be a parameter option. something to adjust in the out of the box Revit. But i guess once its made them i can just apply it to a template, and from now on, i guess it will be. i mean it can't be that hard to program it into Revit. Especially with 15 release, instead nnnooooo, We get sketchy lines. lol =). But its all good, thank you again man. Def did helpl me out.
demension text color
Tue, Jan 31, 2023 at 1:47:01 PM
13
backgrounds for consultants export to dwg
Tue, Nov 22, 2016 at 7:16:16 AM
revision text color
Mon, Mar 25, 2019 at 1:17:50 PM
Edit Color Scheme: "Color" parameter
Wed, Feb 23, 2011 at 10:12:00 AM
Black background on text (imported DWG)
Thu, Feb 18, 2016 at 8:38:47 AM
Page generation time: 0.4539
