Forums >> Revit Building >> Technical Support >> Dimension to something out of view
0 Posts No Rating |
I am working on a plan detail that i would like to dimension the fireplace in the plan to the walls of the room, but the walls are out of view. Is there a way to do this? In autocad i'd basically draw the dimension then put an arrow on the one end and overwrite the text to say the correct dimension. I've attached an image of my view. The 8 3/4" dimension should really say 3'-0". I've tried to draw what i want it to look like too.
You can't dimension to something that you can't see. You could either show the wall or you could use text w/ an arrow to "fake" the dimension
You can also include the wall in the view and split the plan to make it smaller.
Or you can use this Detail Item family. Not a true dimension, but it will do what you need.
EDIT: FWIW, added flip arrows to improve family behavior.
Edited on: Sun, Jan 18, 2015 at 3:57:08 PM
Hey Pijpiwo,
Could you repost your link as a 2014?
Thanks
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein |
0 Posts No Rating |
Thanks. I was going to make a family like this. This will do what i need.
Hey Pijpiwo,
Thanks
Shatner86
I’m sorry Shatner, but I don’t have an access to 2014 at this time. Try building it yourself, it’s just a line based detail item with nested non-parametric tick mark, arrow head and text label – all generic annotation families. Give it a shot and If you’re stuck somewhere along the way and need a help, just let us know.
workaround for dimension partially of view so not shown |
Tue, Apr 26, 2016 at 10:28:59 AM
Split View & Dimension Problem |
Tue, Jun 18, 2013 at 10:06:04 AM
Same dimension strings in different family views? |
Tue, Nov 10, 2009 at 2:40:44 PM
Creating a dimension where one end doesn't dimension to a specific point |
Tue, Jan 4, 2011 at 4:56:37 PM
Activate Dimension |
Tue, Dec 13, 2011 at 12:53:45 PM
Members: | 2115099 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
