36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Total Mark Numbers vs Total Pieces in a Schedule
Wed, Jan 14, 2015 at 1:23:40 PM | Total Mark Numbers vs Total Pieces in a Schedule
cgruwell00
Has anyone come up with a work around to get a total number of mark numbers in schedule instead of total number of pieces?  I have a schedule of piece numbers and would like to know how many piece numbers are in the project.  However, when I calculate the totals in the schedule it gives me the total number of pieces.  Since some of my piece numbers have multiple instances the total piece numbers and total number of pieces are not the same thing.  All the work a rounds I have tried have not worked because revit evaluates each piece individually then totals them up.  Hence the reason you cannot use count in a formula.  See the attached file for my sample schedule.  There are (19) Panel Numbers but the ground total of pieces is (30).  I’d like for my schedule to display a count for the mark numbers along with the total piece count.
Schedule - simple Total Unfinished & Finished numbers- Residental
Sun, Mar 25, 2007 at 7:45:33 AM
Schedule sub total
Sun, Jul 9, 2006 at 10:29:51 AM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:51 AM
How do you total two things in a parking or any schedule?
Fri, May 29, 2015 at 10:59:59 AM
How do I create a wall schedule that also calculates total length of walls?
Wed, Jul 25, 2012 at 6:28:17 PM
Page generation time: 0.4027
