31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Level does not show in plan view
Mon, Jan 12, 2015 at 10:07:14 AM | Level does not show in plan view
mrselle
Using Revit 2015 I have created a basement with a level line (that is blue) through it. The level shows up in the browser under plan views but when I click on it I see nothing. View range seems fine...what is going on???
Mon, Jan 12, 2015 at 10:22:40 AM | Level does not show in plan view
3.5 Stars: 400 Votes
Many possibilities.
  1. The view range is wrong
  2. No model elements cut
  3. The view is cropped away from the model
  4. Nothing is on in VG
  5. Using phases and view is set wrong
  6. Using design options and view is set wrong
  7. .... and more
This is a process problem but you don't give us enough information to help.
Mon, Jan 12, 2015 at 10:35:12 AM | Level does not show in plan view
mrselle
Well, I changed the phase to Project Completed and it showed up...but I don't really know why. At least I can see something.
Mon, Jan 12, 2015 at 10:47:03 AM | Level does not show in plan view
Good opportunity to learn.   Search PHASES in your HELP and start reading.
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
Walls do not show up in plan view
Tue, Mar 10, 2009 at 1:49:55 PM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Plan view levels
Tue, May 5, 2009 at 3:15:03 PM
Revit component wont show up in plan view
Thu, Mar 15, 2012 at 2:55:51 PM
Page generation time: 1.6795
